Hello,
I saw all the detail on milling here and thought this would be the place to come for professional advice!
I work in forestry and own a couple of acres of woodland in Northumberland. I'm very interested in milling a bit of timber with an ms880 and alaskan mill. I have a husky 346xpg for felling and class 2 trousers.
Sorry if this answer is blindingly obvious to you all, but I can't seem to find any detail on the stihl website about chain speed for the 880. Will class 2 trousers suffice or will I need class3?
Thanks very much in advance for any help...I'm dying to give the mill a go.....just don't want any accidents in the process.
Kind regards
There wa wa thread on here a short while ago about trousers and testing. Can't remember the name but I'm sure someone will be able to put a link up.
From what I noticed and gathered from it, it doesn't make much difference as trousers are only designed to stop a slowing chain and not a full throttle chainsaw. So I guess it would make much difference as I doubt a top notch do all trouser would stop a chain going full whack anyway.
Plus trousers all have a label that state they are not designed to protect agains a chainsaw strike anyway. Check the labels inside them....
At full revs, you've got no chance, pants may stop it when the chains slowing down BUT if your using it for milling, I wouldn't worry, once the saws in the mill in the wood, it's as safe as a chainsaw can be really.
No trousers are going to make you 'safe', so its best to have the mentality that any leg hit is very bad ... just be very careful, I often feel people use chainsaw trousers as a false security.
My trousers are both made by different people, the class 3 are jonsered, the class 1 are Oregon. The jonsered are very old so probably was ok years ago and the oregon are new.
I doubt any trousers will stop an 880 at full tilt.... more importantly work in trousers you find comfortable so you don't rush.
Get things set up properly. Using a chainsaw in a mill should mean it never comes near your legs.
