well chaps bit the bullet & got 1, cheers jj,
ran it on a 40/1 mix to bed the saw in then on to 50/1 ,the saw did feel a tad heavier but soon became unnoticable ,have put 4 tanks thru the saw & have tweeked the carb as it had a flat spot on pickup ,gave it an extra 1/4 turn out then back & forth till went & it was fine , vibes feel less which is one of the reason i got 1, may cut down on the cramps / pins & needle 5,times anite :thumbdown: the f/c chain cuts quicker ,i dabbed the rakers early on to make it smother ,chain does sound noiser ? the only real noticiable differance i found was the engine noise ,
shame thers not more plastic on the chain brake ,
the on/off switch is nice & smooth ,dosnt seem to catch branches as much
allround a good improvement on what was a very good saw
dont for get we have to deal wi the emmissions on 2/st engines
this only my opinion, no doubt some will have thers & differ :001_smile:
Edited by Johny Walker
i forgot not use to typing s/as:laugh1:
yes i love mine as in pic << tweaked the carb as you said, drinks a tad mor enow but screams:thumbup1:, cuts well, been spot on so far, well chuffed:biggrin:
You must own an auction or something because of you used this saw everyday you notice it's flaws! Useless on hardwoods
strange you say that,iv takern down 2, large cherrys with no issuse other than a tweek :biggrin:
is your chain sharp :sneaky2:
