  • Replies 32
Looks good,
A friend who I work for as a mog driver etc & other things has a similar outfit
A U1500 with a PF9000 remote control double extension demount on the back, a Werner F64.1 M1 SW/C P.T.O winch with remote on the front, a 13.5T Müller Mitteltal tipping trailer with higher sides (17m3) which normally gets paired up with a tracked 10” chipper.
Looks good,
Sounds good!!!:001_cool:
Wish I had a built in winch.
I must say, I would be far happier with the crane mounted on the vehicle, not on the trailer...
Why are you not on your way to Hurst Green??????:sneaky2:
Me to,
the demount PF9000 has 4 legs with the front 2 legs set at an angle so the can extend just forward & out of the front axel, couple this with being able to lift the 8.5t mog completely off the ground makes lifting at maximum weight/reach very stable/level & when you just need a crane you don’t have to take a trailer! ;)
Me to,
Pictures:001_tt1:
Our u1500 has the crane mounted on the rear and tows a similar trailer to Skyhucks, we then have a U1200 with a chipper and chip box.
This set up probably cost less to buy than skyhuck's all singing all dancing single mog but for a one team set up, who I assume will only need the crane and trailer at the same time its probably the best set up for him plus if you put that crane onto the mog there would be no room for the chip box.
