You won't be disappointed :) bigger is better, but stihl is best! (cue husky lover replies! :001_tt2:)
Get a dual port muffler, get the carb tuned for it and it's a beast. The dual port is the same on the 660 magnum or R versions. Can be found on eBay!
thanks mate, will do the mods :thumbup1: cant wait untill i get a big job to warrant £909.00 on a saw:001_huh: got a few big jobs in pipeline so should own the beast soon:thumbup: thanks again lads.
  • 2 months later...
  • Replies 65
at last
and pm spud
PM'D.
he said easiest way & cheapest way is to enlarge exhaust output with dremel:biggrin:
josh
Like I also said in the PM - make sure the carb is adjusted to the new exhaust, there is a risk the change may make the saw run lean and do it some damage.
The dual port muffler is part - 1122 140 0800 and is the front part of the muffler only - you may have trouble finding one in the UK as a quick check online hasn't found one but dealers may be able to hook them in!
My solution was to open up the restrictive exhaust outlet hole and the internal baffle plate until the saw has bareable noise and an increase in flow. If you have the tools, the cost is free and relatively easy to do.
These big saws are damn loud with muffler mods!
