Depends. If I really want to be sure not to lose anything off the end then I stick some old gloss paint on. Otherwise, I usually don't bother. I've used bituminous paint too in the past - anything that will stick and slow down the rate of moisture loss will do the trick but I don't want something that might melt again afterwards as it's liable to smear and mark the boards, or to soak in which means you're sacrificing the end anyway to get rid of it and you might as well not bother to paint it then.
Alec
As above PVA works well - it's cheap, non toxic and easy to paint on .. I do think it makes a difference although as Big J says it's further down the importance list than the other things he's mentioned.
