What better to do after a long day on spikes than come home and crack open the Tirfor?
Here's the old girl, and the part I had left over when I put it back together last week.
So I opened it up, manky inside. Got a big bucket (£10 form B&Q) and a big bottle of white spirit, and started scrubbing. All sorts of shiny metal appeared. It's now in the hsed having a long soak, I'll flush it out tomorrow. Meantime I cleaned the inside top cover. Reminds me of a roasting tin I had once. Not bad for a winch that's probably 40 years old.
Now, where did I put that chicken?
hi
having got to the clean stage what will you grease / oil it up with ?
i pressure washed my cheapo copy after a muddy day and just dried it on the boiler and squirted wd 40 inside and on cable
the wrong thing ???
thanks
david
hi
the wrong thing ???
thanks
david
Most oils work fine in tirfor, don't think they are too fussy.
I have poured some engine oil into mine, I have also used hydraulic oil.
The official word from the manual:
The machine should be inspected, cleaned and
lubricated at regular intervals, at least annually, by an
approved TRACTEL® repairer.
Never use grease or oil containing graphite additives or
molybdenum disulphide.
To clean the machine, allow the machine to soak in a
bath of some proprietary cleansing fluid but not acetone
and derivatives or ethylene trichloride and derivatives.
Then shake the machine vigorously to loosen foreign
matter and turn it upside down to allow the dirt to come
out through the openings for the operating levers. Allow
the mechanism to drain and become dry.
After this treatment, ensure that the machine is
well lubricated by applying a quantity of oil (type
SAE 90-120) onto the internal mechanism through the
openings for the operating levers, and for the models
TU-8 and TU-16, through the special lubrication holes.
To carry out this procedure, it is best for the machine to
be not under load and in the released position.
Alternatively operate the forward and reverse operating
levers to allow the lubricant to penetrate all parts of
the mechanism.
N.B. Excess lubrication cannot cause the machine or
wire rope to slip.
Any machine where the side cases show signs of dents....etc, etc etc.
  • 6 months later...
Hi, I have just got my hands on a Tirfor T13 Winch, but i'm having problems removing the cable, I'm not able to get the Rope Release Lever all the way back to the groove it sits into to release the cable, anyone had this problem or know how solve it. I presume i'm doing the correct procedure to release it by pulling the Reverse Lever forward and then the Rope Release Lever should then move easily into the groove ?
