Connectors for tool strops
Mesterh
Carabiners for saws come under LOLER so if they are defective they should not be used, However rigging carabiners only have to have a 2 way action. IMO for the sake of £20 a couple of correctly working attachments is not too much to expect.
Cheers for the info and ideas.:thumbup1:
Didnt realise the tool crabs needed LOLER!
Although the ones I use still work fine its just when I buy new ones for climbing they get moved on.
Interesting about the wire gate instead of the caritool(which I use and do like) how do they compare or should I say why the change?
I've got a couple of caritools for clipping the 020 to and an old twist gate that gets stuck on the end of the strop.
I prefer the caritool as it has a flatter bit on the spine. I would have thought that wire gates would work themselves flat wouldn't they? Be a pain in the arse trying to clip something in when the crab is flat IMO
