white smoke
john p
If it’s the 500ci engine then like the 330ci engine it uses an end to end water flow for the cylinder head/block therefor there are NO water ports between the head/block only the oil ports, so 330/500ci seldom have head gasket problems.
White smoke after prolonged tick-over/low power use especially if using red diesel is to be expected, as most engines will have had their injection timing set up for DERV, even so dependent on the age of the engine (we are talking bedford 330/500ci here) modern DERV vs. 1970’s DERV has some differences in ignition quality thus timing.
If you start it in the morning do you get a vaporous light smoke that stings your eyes a bit? If so that is normal and is unburnt fuel from slight mistiming vs. a cold engine and it is this that after prolonged tick-over/low power use causes the white smoke as the condensed vapour in the exhaust burns off once you drive off after doing crane work or winching etc etc.
yep 500 ci,those exact symptoms,good diagnosis!is it worth re timing pump?or is it a lot of ball ache?
  • Replies 22
He's da MAN ! :thumbup:
That's why this forum is brilliant as there is always someone round the corner who just knows
ohhhhh its like mechanical porn :biggrin:
also is it running at normal temp as the stat stuck open wont help and you could try having the pump timing check and advanced a tad that will / should stop the smoke probbs also tweek the tick over up a bit as the old 500,s dont like idling under hiab load etc they suffered very low engine oil pressure some had a electric oil pump fitted on the turbo versions
ps has it got inline pump or a rotary pump fitted check the timing lines are bang on or advance a tad clockwise past the line by a fraction where the pump mates up to timing cover
its all just age/wear design and how its used related
