on start up or when ive been doing crane work or winching when i get on the road and give it some beans theres loads of white smoke for a couple of miles, which indicates unburnt fuel? which is most likely cause,bad injectors,faulty return,pump timing or something else?its on an 8.2 bedford engine. originally engine used lift pump but now runs on electric pump,would this make a difference cheers:thumbup1:
  • Replies 22
black smokes unburnt fuel, bluey whites oil, whites water?? could be condensation clearing ?
ah,could be,got my colours mixed up! she does use a bit of water,getting head skimmed when changing cab so maybe that ll sort it
Try increasing it a bit next time, not much more than tickover. Could be a build up if fuel condensation or exhaust gasses that need clearing when driving.
