I've got a Marlow 12mm double braid line, it's very grippy which is great for lifting with my grcs but eats good quality rigging gloves for fun as its so grippy. Seems to glaze pretty easy as well
  • Replies 24
Cheers for that john, info i needed......:biggrin:
so it glazes easy, ?? maybe i should go for a yale double esterlon or polydyne instead,:confused1:
It's Sirius I'm using not liros. I'm happy using a pretty static line for rigging. If your just lowering get double esteron. If you use tensioning or lifting as well as snatching in the same tree I would prefer a more static rope and work with good groundsman when you need to.drop pieces into the.system
i know what your saying mate, just thought i might give the marlow doublebraid a go, just getting some info see its worth it?
Majestic get some portland braid it's cheaper than DE and PD i use 14mm portland braid, i think it's nice rope. I've also got some 16mm PD for negative rigging big lumps
