PRO TIPPER©LTD.
Ā
You are looking at the Pro Tipper© - a tipping bed conversion for your pickup truck.
Ā
[xfloat=right]http://www.arbtalk.co.uk/images/tipper.jpg[/xfloat]The Pro Tipper© can be quickly fitted by any competent diy'er. It requires nothing more than removing your original tailgate, running an electrical cable, and bolting in position. It requires NO cutting, welding, modifying or damage to your original truck. It utilises original mounting positions to fix securely in the back of your truck.
Ā
The Pro Tipper© completely protects the original bed, wings, lights and headboard of your truck. Even under the most arduous conditions and loads, the steel liner will ensure that the condition of your truck stays as originally intended.
Ā
Using our patented chassis and tub design, the Pro Tipper© sits low in the bed, only 50mm off the original floor. Using twin tipping rams for maximum tipping force, the simple design ensures a long trouble free life for the unit.
Ā
Do you want a tipper truck for occasional use but don't want the hassle of an extra tax, insurance, payments and maintenance of an extra vehicle? Then you need a Pro Tipper©.
Ā
The Pro Tipper© is designed and built in the UK by a small family owned firm. As long time owners of pickup trucks in business, we have worked hard to ensure this pickup accessory is exactly as WE would want it - not as a salesman would imagine it should be. Built tough to withstand proper working conditions, the Pro Tipper© is perfect for the small builder, tree surgeon, landscaper, gardener, farmer, fencer or handyman.
Ā
At this moment, we have units in D40 Nissan Navara, Toyota Hilux, and Ford Ranger trucks. If you have a Mitsubishi L200, Isuzu Rodeo or VW Amorak, we are more than happy to custom fit a Pro Tipper© to your truck. We can build units to suit double, single or king/space/extra cab model variations.
Ā
If you would prefer us to fit your unit, we would be more than happy to fit it 'while you wait' for a small fee.
Ā
We have a range of accessories for your Pro Tipper© including headboards, high sides, lockable tops, radio remote control systems, and LED beacons.
Ā
Call us on 01353 648 628, or 07875 386674 for details, or email us at [email protected].
Ā
For more information visit http:\\www.protipper.co.uk
Ā
Here is a Pro Tipper© in action with a full load of fresh woodchips. Notice how the tailgate protects your bumper and tow hitch from the load.
Ā
Ā
Ā
Thanks Steve, I am more than happy to answer any questions on the forum, and I'll be adding pics of new designs as and when they are built.
What's the maximum it can tip? Weight wise?
Ā
Looks interesting and can it be removed easily as it went in if the truck it is fitted to is multi purpose?
Prices start at £1500 for the base model for a double cab.
Ā
What flat bed vehicle have you got?
Ā
I can remove my unit from the Navara and refit my canopy in approx 30 minutes, takes about 45 minutes going the other way.
Max weight, I have put 1000kg in mine and tips it, in practise the legal payload will be around 800 kg.
Ā
Galvanising is not really suitable as the sheet tends to distort, we use an etch primer which chemically bonds to the steel, and a very hard gloss top coat.
  • Ā
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. Ā
If you're just starting out and you need business, equipment, tech or training support you're in the right place. Ā If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,Ā Ā then you're welcome too.
Ɨ
Ɨ
