Coronet cuts on elm for habitat
sanny
quality of camera not great so need to ask santa for a better one :santaclaus:
some pics of me trying out different styles of coronet cuts on an elm.this turned out to be a nightmare to climb because of ivy as you'll see in pics nasty stuff:thumbdown:
  • Replies 33
Good to see different techniques being applied up and down the country.
Was this your first time?
Is it in a Clients Garden?
Not sure due to photo quality, but is the tree alive or dead?
If dead/monolithed, it looks quite close to targets to be left at that hieght.
Will someone be monitoring it?
Personally would have stripped the ivy well back from where you make the incision cuts for the coros. You need to be completely sure where the tip of your saw is at all times.
David
Here's some I did the other day on a Scots Pine these were my second or third attempt in maybe 5 years, not too many people are willing to let this be done. I find they want their trees perfectly manicured. I did this primarily for the wildlife habitat but also not to cause a huge wound on the main stem. There was a dray and woodpecker holes on it. The rest of the limb had to be removed because it had a great deal of end weight and numerous wounds along the limb. It's in a private garden open to the public.
