Has any one had problems with ranger rear axles ??? Mine had a strange sound from prop shaft has developed on to a small oil leak prop input on rear axle and a vibration at 70mph its 55 plate less than 70k on the clock.
My 56 ranger had a faulty diff and notchy gear box at 26k, it was a great truck but had to sell it as I'm a car nut and needed something practical and fast.
you might have a little dent in your propshaft that can cause a lot of vibrations iv had it on a hilux if it has it will cause the prop to run out of line and cause an oil leak from the seal if it has you wanna get it fixed befor it breaks the diff
