Can someone help identify this giant evergreen?
Hello,
I've just bought a house with two giant evergreens (see attached picture) I was hoping someone could tell me what they are and how I can manage them.
They are a bit too big at the moment, have no real truck mass, just many thin shoots and are quite dusty when you brush past them.
Can anyone tell me:
What they are?
If I can cut them to 6ft without killing them?
If (once cut) they would green up?
Many Thanks,
Will
Taxus bacata 'Fastigiata' by the looks of them Irish yew. The dust is the pollen they're producing at this time of year and you'll be able to clip them successfully.
Thanks so much for the identification. From images of other trees on Google you seem to be spot on. With the help of your identification I have searched the web and found that Irish Yews do respond well to trimming. I do however plan to cut down quite a lot (to about 6ft high) and was wondering if this would be considered too harsh a trim?
Any ideas how long it would take to green up and what time of year is best to do the cutting?
Also, will it green up from the sides as well as the top?
Thanks again,
Will
Edited by will77t
You can reduce them in height and they should respond ok. I'd get it done asap before the birds start nesting and you'll have this season for regrowth.
They defo respond well, I did two before I left the UK, cut them both flat on top and a little side trim and they looked great at either side of the gate.
steve
You won't find it in BS3998 but we've ratchet strapped them really tightly before now and then wired them up before removing the straps, and then cut them back hard around the sides to remove any bulges (making sure you don't sever anything that is supporting life further up the tree obviously). They look terrible when you first do them but they grow back well within a season and end up a lot narrower and more formal looking. You need good strong wire, you can apply a lot of tension with a 5 tonne ratchet strap and you don't want it going pop... (before anyone shoots me down for tree mutilation, this was done as a last resort as the owner was going to remove them otherwise). They now look fantastic as they are regularly cut with a hedgecutter.
