I friend who is a coppicer (is there such a word) and he has an old tractor which needs a replacement part and he cannot find one so I said that I would ask in herr....
The tractor is an Alice Charmer ED40 1963
Engine is a Standard motor co 23C
The part is a rubber tube with different size apertures one end is one and three quater inches and the other end is two and a quater inches,
Pics below
Can anyone help please
go in to ur local agriculture spares place (not ur large main dealership type but your cheap any part fits kinda place!) and say have u got something to match this. Or failing that you can get convoluted replacement radiator hose and u'd probably find u'd get a size to squeeze over the one end and tighten down the other with a jubilee clip or two. :biggrin:
I cannot help but we had one as a loader tractor on the second dairy farm I was employed, strange thing with a hand clutch and a foot clutch. Anyway I think it was the same engine as the 4 cylinder MF 35 before they changed to the much better 3cylinder perkins.
Hi
Thanks Mike the guy has tried that approach with no luck, the two ninty degree turns happen in such a short space that the things that he has tried so far do not work. I am sure that he will eventually find a something that will adapt but it seems worth looking for the correct componant as well.
Search ebay for a silicone 1 3/4" to 2" reducer bend and a 2 1/4" to 2" reducer bend, bit of 2" pipe in between and you're sorted.
thanks, i will pass that on
If there's not quite enough space between the two contact this lot, they'll be able to make you thanks........
.......................i contacted them and they quoted £500+
