Stuart we have two Navaras & have loaded HB20's before, the ropes will stand the weight but you can stress the hinges as they are weaker than the ropes!
Also beware of the ramps running off as the tailgate is slippery plastic.
You should be able to pick up a cheap unbraked trailer intended for carrying a roller or similar. Once you have the grinder on your truck the c of g will be high and you need to take the ramps to unload other end. Having the buck empty leaves room for other things.
