Need a oil pump for MS361
justinh
Hello
I need an oil pump for my Stihl MS361. The whole system wore out and overheated so I need to replace the whole system.
Where is the best place to order the parts online?
I've found the workshop manual online so can get the part numbers.
cheers
Justin
You will need 1132 640 3200 pump at £35.86 and 1128 640 7112 worm at £5.20 all plus vat.
Many pumps fail due to the clutch drum wearing them out when the needle bearing fails, so its worth checking that out.
If you still require the parts, I can get them. PM me if interested.
