255 60 R18 tyres looking for chunky tyres
D.M.Taylor Firewood Supp
Looking to replace tyres on my isuzu rodeo been running on a set of general grabbers rear tyres did 25k mostly towing trailers.But as far as im aware they stopped making them.Idealy i want a set of chunky off road tyres as do alot of lamping.Any you guys know who makes any what ive been told nobody does any is this true??Thanks
  • Replies 24
I am having exactly the same problem my old isuzu had b f goodrige on but i cant get any in 255 60 r18 general grabbers are ok but i would all so like something more chunky ive been looking for ages
Hi Darren, yes the General Grabber has changed pattern style due to new European laws regarding off road tyres and whilst it doesnt look as good as the old style, it still got rated very highly in the Land Rover magazines. Doesnt appear BF Goodrich do the all terrain in that size but it might pay to ring the usual suspects - John Craddock, Paddocks and Silverline.
Good luck,
Derek
That is a funny old size...! Cooper STT is close, may or may not fit, will be a bit bigger than what you're running... closest is LT275/65R18, 50mm taller/25mm larger radius and 20mm wider/10mm each way than existing 255/60R18... all things being equal [discounting additional tread protrusion and apart from the fact that it might foul bodywork etc,] you will lose just under 3 degrees from your maximum steering angle in fitting this larger size. Good tyre though....
So can i put 255 55 18 on instead of 255 60 18 with out affecting the handling or steering i no nothing about tyres:blushing:
55 is just a slightly lower profile, basically 55% of the width rather than 60%...
here is a useful bit of 'rithmetic for you...
255 - width of tyre in mm = 255mm
55 - aspect ratio, or height of sidewall as percentage of width, 55% of 255 = 140.25mm
18 - Wheel diameter in inches, or in mm it's times 25.4 = 457.2
Add that lot together, 457.2mm + 140.25mm [x2 for top and bottom of tyre] gives you a diameter of 737.7 diameter [doesn't allow for variations in tread depth & projection, all tyres are different]
A 255/60R18 has a sidewall height of 153mm, so 13mm taller than a 55 profile near as makes no difference... That's not a lot but bear in mind you're losing that space beneath your diffs...
