I am about to ebay a friends MS200T (he is not internet savy by any stretch) my question to you guys; is it worth fitting a new sprocket cover & air filter cover. The current sprocket cover is very scratched and has the usual exhast scorch, the air filter cover is also scratched and has a small crack in it.
My thoughts are to sell it as is, however he thinks it might be worth spending the £30-£40 for the new parts so it doesn't look so beat up, in all fairness it isn't that beat up for a 10yr old saw on all it's original covers.
You thoughts please
C B
I think the side cover is around the £30 mark - part 1129 640 1702.
Personally I would clean it up - will let you know a couple of tricks when you pick your saws up:thumbup:
I always fit new sprockets if they are shagged - just feel bad passing on crap to others less able to fix it after paying well over £200 on a saw - but thats me......sprockets £15 and clutch springs are also always buggered - I generally fit these to machines I sell as again it is a safety issue if the chain spins at idle!
Generally the chain catchers are missing as well and so the story of my refurbs continues........:001_rolleyes:
May be interested if your mate doesn't want top dollar for it - need to make a living!
Well i have just spent a cold evening worming crap out of every orafice i can get access to on this, Steve if you thought my Rancher was packed with crud, this was a belter, jimmy jam packed.
It had been a bit of a pig to start..... reason; the coil contact points that interact with the fly wheel (no idea on technical name) had a good 1mm of insulating sawdust and oil compound on them which i have now cleaned of. It now starts first pull :thumbup:
Very tempted to buy it myself as i imagine it would be quite handy for hedge laying although not sure if HSE would like it being used on the ground one handed whilst bending a bit of hedge over:001_tt2:
C B
