REF what size snatch block for a 6 tons winch thank
mendiplogs
why would you want the biggest one you whant it to be best matched to the load so double the load is 12 tonne so 16 is the best matched and not to heavy to lift but with whinch wire to do not wount to bent it to tight so you wount a largish sheave
ps this is for one pulley
Edited by NI Tree
HI NI thanks for that mate i will ring clacks ref a 16 ton thanks jon :thumbup:
There are - or at least there appears to be - a couple of misconceptions in this thread which may be potentially dangerous.
The winch is stated to be 6t line pull, normal good practice would be to use a snatch block with a SWL (Safe Working Load) of not less than 12t however such a block will be large and heavy and is only really required in a lifting operation.
The unit offered by Clarke is listed as having an Ultimate Tensile Strength of 16t that does not mean it can or should be used at anywhere near that loading. Some factor of safety should be applied.
In reality however I would imagine that the winch in question is fitted with a wire of approx 12mm diameter? Such a wire will have an MBL (Minimum Break Load) of about 8.5-9.5t when new. Accordingly the snatch block should have at least that MBL - which in this case the Clarke unit does. In addition the 6tonne rating for the winch applies to first layer service only and falls away rapidly as the drum fills with wire.
It is (with apologies for advising on eggsucking) really important that the anchor point for the block is similarly stronger than the wire, in the event of a failure of the anchor point the block tends to land in the winch operators face
HI mate yes your right its 12mm wire as new so what do you think of the size i need will a 15 ton will do thanks jon :thumbup:
