No. Barrel and crankcase on 020's different to 200t's so not interchangeable.
the part code for one side of the crankcase: -
020T - 1129 020 2600
MS200T - 1129 020 2601
The other
020T - 1129 020 2900
MS200T 1129 020 2903
I have to say that I thought both barrels would work but have never tried it although they look very similar with the MS200T having a splitter running down each transfer port as the only obvious visual difference.
I am not disputing your statement but have you actually tried it and what are the differences as I know I have a MS200T that may need a new cylinder and one option was one off a 020T......until I read this:thumbdown:
The other
I have used a 020 barrel on a 200t, worked great.:thumbup1:
Well I couldn't tell the difference.
Can't remember what gasket I used though 99% sure it was the 200t.
I thought that may be the case - a manufacturer will try to use standard components whereever possible and I have had a fair few 020 and MS200Ts appart and always looked very similar appart from the transfer differences. The piston is universal.
I think pleasant was going on the part code differences but Stihl often have the same parts but just change the last number by one for each saw type.
Let me know what you can find, I've got 3 spares that customers left with me due to carb problems and they didn't want them anymore. Can break one down for you, will comp test them just to make sure one will be ok for you.
