Just a thought.... I plod on growing ash, alder and oak from seed but wondered if I could just poke a cutting into the ground as per willow.
Anyone with any experience / info or is it just a daft question?
You can get most species to take from cuttings, but you need to use semi-ripe wood in about June, poke it into sharp sand/compost about 50/50 mix, and to give it some bottom heat. Success rates vary from about 30% to about 80%, depending on species.
The other option if you're doing a lot is that some species work well from stools. This is like annual coppicing, earthing up to promote rooting. This is how commercial rootstocks for fruit trees are produced, along with hazel, chestnut etc.
Alec
Edited by agg221
Remember planting lime trees which where rooted cuttings, Hazel can be layerd in the ground for 2 years and then cut and planted, Black poplars cuttings are took from good gean stock and growen on.
Obviously I've no idea what you want the rooted cuttings for but cornus do well as sticks stuck in compost.
