the basis for chainsaw maintenance is whatever the manufacturer recomends like it is for all vehicles and machinery
rubber av,s were supposed to be replaced between 6 and 12 months due to vib levels
springs last till they bust as they do not deteriorate i usually change fuel filters every christmas as for me prevention is always better than cure and replace pull cord if the slightest sign of wear
reliability is worth more than a couple of quid
how long do you guys reckon on life span of bars and sprockets? change every so many chains or only when showing signs of wear?
Sprocket every few chains, bar when bu**erd.
i change bars and sprockets when they are worn
you can get a little guage from stihl to check your sprockets for a couple of squid which is a lot cheaper than a new sprocket and a bar dressing tool will be a very good investment too
