flashing Becon Problem Transit tipper
hi guys,
having abit trouble with my flashing becon. problem is its not flahing.... i have checked the bulbs the conecters on the switch . it doesnt seem to be wired to the fuse box. any body got any suggestion to why it has stopped
its a 2002 crew cab transit if thats anyhelp
recently sorted mine in my iveco, i checked the bulb, traced the wire through the dash, removing parts as i go..... it ended up being the switch in the end lol, use a multi meter and get stuck in :)
yes
and its not lighting up
check to see if its getting power to the switch, trace it back, theyre a 3 pin switch arn't they? well mine was... it was lighting up on the led but then not switching the live over to feed the light :)
yeah 3 pin switch . i dig out a multi meter and let you know the crack .. cheers lads merry xmas
should be an earth, live then nothing on the other wire till its switched over..... you can try joining the two lives together (manually switching the current instead of the switch) to see if it works.... :)
