I ordered some OP and OV has been delivered in 8mm. Tried serarching online for it but i can only find OV in 6mm. I am about to splice up some E2E's but i'm just wondering if its the same, just a different colour?:confused1:
Mmmm.... i'd better find out for sure that is green and yellow OP that i've spliced as i've done a class1 splice on it! Its construction looks the same as the conventional coloured OP that i normally climb on.
Do they do OV in 8mm? All the searches i've made online only mention a 6mm OV. And, i can't find any reference to a green coloured OP!
Its a bit scary that they make 2 ropes with different construction, the same colours!
There a million ropes that look the same! Your hitch is op, so class 1 is spot on.Ive spliced up the ov and will probably test the class 1 splice but tbh it's too thin to be used as hitch cord anyway.
Edited by DrewB
