Im after a little advise please. I use an edelrid tree motion 2 to climb with, whilst doing some conny bashing I nicked the bridge with my silky. Now its not a big cut but it is a cut all the same. I was wondering if I should get it replaced? If this is the case has anyone done a bridge change on this harness before or is it a send to the pro's to do job.
ย
Or am I worrying about nothing? If that is the case what would the loler inspector think about it.
ย
Thanks for the input in advance.
ย
Forgot to add that i lightered it to seal it
  • Replies 29
think u have already answered your question mate. end of the day its ur life, and any doubt in ur bridge should be silky cut all way through and get a new one.
ย
Thats how i think about things ay, only fiver to replace.
ย
Cheers Mog
Hi there I did the same thing to mine a while back with my silky I did replace mine but it was worse then yours . Its easy to do a bridge change you will be able to order up another one and may well have it by the next day if you ring them first thing in the morning .
ย
Give Justin a ring at Jones he will sort it for you . If he has not one in stock try HB they are quick to deliver as well if you ring first thing in the morning .
ย
All the best
Littletree:thumbup:
Thanks for your posts on this, I think your right by saying I answered my own question. If I have to ask then the only way to go is replacement.
ย
I have contacted Chris at f r jones and he will get me one in in the new year. I can borrow one until then so not so bad.
ย
Thanks for putting my mind at ease
I replaced the bridge on my dragonfly last week, it didn't have any noticible marks, nicks or fraying..... but for the sake of 12 quid i can be safe in the knowledge that its good to go and fingers crossed safe and sound.
dosent look too bad but the way i see it is they made it size and thickness for a reason so for sake of a few quid you dont have to keep looking at it the higher you go.
  • ย
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. ย
If you're just starting out and you need business, equipment, tech or training support you're in the right place. ย If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,ย ย then you're welcome too.
ร—
ร—
