...How are you getting on with the combo Dave?
It works very well for smoothing out the control inputs on the Uni and having a RW over the Uni does significantly reduce wear.
It is hard to see but I put a rubber grommet inside the closed ring of the clip. This prevents the RW from swinging closed under its own weight.
Unfortunately it gets little use lately as I prefer using the Hitch Hiker.
Dave
I like that idea, I'll be trying that. Cheers
