which log splitter??
carlos
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=230302668875&indexURL=0&photoDisplayType=2#ebayphotohosting
i saw these at the apf they look very good one man can lift the unit will plug straight on to the mog
i built my own own splitter which i use on the mog hydraulics
hello,we can supply the log splitter for you.Electrical log splitter and gaslion log splitter and so on.
msn:[email protected]
skype:lxpfair
hi we are thinking of buying a log splitter for the back of a mog. any advice on which to go for ie pto or striaght hydrulic, makes models etc. thanks carl.
I had an old wessex hydrulic one one that sat on my 3 point linkage. The only problems were i had to bungy the spool valve lever open as it used to pop back to centre after a few minutes running when the oil had got warm.
Also the mog linkage didn't drop quite low enough (even adjusted) to get it on and off easily so i allways had to have it sitting on a couple of 8" logs.
I also only ever used to let the lads run the mog for 30 mins at a time before giving it a break as you only just need it on idle.
