No worries mate,i was thinking the same about myself before seen you say about it:lol:
Second that! Always makes my nose run and gives me a sore throat after sanding. Normally passes after a few hours but even with a dust mask makes little difference....................worth it though!:biggrin:
  • Replies 34
lasts a couple of days with me.... but then I do coat my airways with about half a kilo :D
Finished.
slick wet finish with more shine than Liam Gallagher & a L'oreal advert combined.
5 coats of water clear lacquer - sprayed.
Best bit was giving it to the people I made it for. And the response I got from them.
Gorgeous!!
What's the set up cost for spraying the lacquer?
Thankyou!
spraying, hmm, swings &... really.
You can buy kits out there, but as in anything, you get for what you pay for.
You want a compressor that can deliver a constant 30-50psi without dropouts, and then tune your air / paint mix to suit. Too much paint=runs & orange peeling etc, too much air, gritty finish. You definitely need a flow regulator on your gun if there isn't one on the comp. You cant go chucking 100psi thru a gun - well you could, if you could dial in the paint amount to suit and were robot efficient at it !
Guns, you want a HVLP (thats a type) gravity fed gun - so much better than the old "suckers". 100£ is a good start. you want a gun that you can change the nozzles on (20 a go) if you want to spray water based and solvent based - which I'm sure you will.
And practice with paint/colour first - lacquer is much harder to get on - because you cant see it.
300£ would be a handsome setup. Good gun and line, filters, bits, a nice second hand quality compressor - definitely no clarke rubbish :D
Thankyou!
Cheers mate, some great info there, I take it you've got some sort of spray booth too.
Is the water based stuff easier to use?
What's the stuff they use on cars? I was thinking of befriending some car sprayers and doing some in their quiet spells.:sneaky2:
Table looks great.
For the record, every bit of Yew is poisonous and caution should be taken at all times.
Having said that I always forget the face mask and spend the next few days choking, astmatic as well think I'd learn, haven't done yet after 30 years of sanding.
