First off, what saddle are you guys using?? I'm looking at the freeworker site, and I really like the TM, Kolbri Multiside, the Tree Magic, Tree Flex and the TA3. I'm having a hard time deciding which one. I've sat in a TM before, and loved it!!:001_tt1::001_tt1::001_cool:
But, it's a little expensive. The other's though, their more in my price range. I guess my first question is, is the TM worth it?? Should I save my cash for it, or go with one of the other harnesses?? Thanks alot!!!
  • Replies 27
My experience is very limited but the only one I got on with out of the many I tried was the Tree Flex, but then I know loads of people who hate it. Have you tried them all on?
If you loved the TM I think you should probably get saving!
Certainly not disappointed with mine....I do think people harp on about the cost too much...once you learn of the value first hand in owning and using a harness that is ergonomically designed to adjust to your skeleton and the demands of tree work specifically, I think you will no longer see it as an expense, more an invaluable investment!!
Whatever you decide to run with , and there are a few just now, try b4 U buy!...:001_smile:
EDIT: I just checked out the Tree Magic and it looked like a fairly comfortable saddle, with alot of options. I've talked with a few people that have one or have tried it, and they really like it. What's the members take on this saddle, since it's more in my price range.
I've just got the Tre Austria 3 and it's a decent harness, little more fiddly than the two to put on but very comfy.
The only niggle is when you are hanging from it and twist right over to either side, the ring goes over the stitching on the end of the bridge and you have to give it a little jolt to get it back over the lump of stitching, if that makes sense
