0.325 sprocket for 066
RDB logs
Do you have a spur or rim sprocket set up at the moment?
I am not aware that there is a 0.325" spur sprocket that will fit. You can however get a 9 tooth rim sprocket. You can get higher teeth numbers but you would probably have to get it from a saw racing specialist.
The 066 uses the standard 7 spline like many of Stihl's saws. The part numbers for the rim only (9T 0.325") (no clutch drum);
Stihl 0000 642 1239
Oregon 13624
I wouldn't have thought the strength of the chain would be a problem. Chip clearance might possibly be an issue but with only 20" you will probably be OK.
Thanks megatron thats good of you to provide part numbers. I had resigned myself to a new bar,
As for the strength issue i will be running it on one of those portec log things to cut green sycamore thinnings so it will be at only 1/4 capacity.
If i were using the 36" bar to log seasoned oak it might be a different story!
Thanks again all as im new to this forum and computer thingy!
