Thinking of buying a mobile mill but the choice is baffling.
I'd like one that's able to saw both sides of the timber, creating a 90 degree angle rather than being limited to waney edge.
Are these called 'resaws' or have I got that wrong?
Alternatively, is there a reliable technique for cutting both edges uniformly using a standard mobile sawmill?
Being able to cut featherboard too would be nice, but that's probably unlikely for a 15k budget.
Thanks
Edited by TreeNuts
from what i've laboured behind, all mizers can cut square timber, only a case of turning the timber 90degree's and making another cut. but i'm sure they're some serious skill to doing it well. Only seen a peterson saw working once and it was great for cutting square timber but ur restricted to the width timber u can plank compared to a mizer in my opinion. just my pennies worth.:biggrin:
Mizers are alot of money for what they are. I run a Hudson mill, and you can cut perfect 90 degrees by turning the log, as you can on any horizontal bandsaw, but I reckon i got a hell of a lot more mill for a lot less money tahn a mizer TBH.
A swing mill Lucas or Peterson cuts dimensioned timber without having to move the log
I have a Lucas and it has a featherboard and slabbing attachment
Not sure what the price is now but i think i paid about 16000 Aussie dollars in 2004.a lot more models avaliable now too
You should be able to buy one for less than 15000 pounds i would imagine
So can you move the blade from the horizontal to do the vertical cut using one of those mills?
Just so I understand this: once you make the first horizontal cut, you turn the log and it rests against a vertical plate, which then allows you to make the second horizontal cut, forming a perfect 90 degrees?
VERY versatile mills indeed. The are essentially a petrol driven circuar saw on a superb ali frame that you build around the log. The saw cuts to a max depth of 8", and can be set vertically or horizontally pretty much at the flick of a switch, hence you cut slabs or beams directly out of the log.
[ Home ] LUCAS MILL Portable Timber Sawmill
Yes.:001_smile:
