If there's subsidence then the builders at fault, nowadays building on clay soils....ooh, hang on a second, Becky Mantins doing the weather :001_tt1:... right where was I?
Oh yes, Building on clay soils should be on a raft foundation and therefore unaffected by shrinkage and Heave.
I had an Insurance company blame next door neighbours poplars for a porch showing signs of subsidence. The poplars were 50ft away.
The foundations on the porch were non existent, some diy muppet had built it and then some insurance muppet wouldn't renew insurance unless the trees came down.
Muppets!
Cheers Lee, thats a better photo than mine.
If you see me logged on and not posting, I'm just pulling my pudding looking at becky
I see your logged and no one is at home!!!!:scared1:
I dont want a call being blamed for something and i new you guys would have details on it.
Cheers for the info should be fine house was piled so the tree should be ok to remove.
:001_smile:
As I understand heave – it will only occur if the tree is older than the property and that property was built on desiccated ground (e.g. in a drought)
It takes these two factors in order to produce heave, if you dont have them, you wont get heave.
