  • Replies 32
cheers for the replies.
interesting about the echo i thought the hedge cutter would work with the extention that would have been handy, i know the hedgecutter head works on the stihl but can damage the shaft if you cut through bigger bits.
im thinking the stihl ticks the boxes, pity it has the 4 mix..........so it could be the echo:lol:
I used an old echo one, on full extension it was seriously heavy when horizontal.
Fwiw I have a 4 mix blower strimmer and long reach hedger, not had any bother with any of them.
TD Tree & Land Services Ltd.
currently got three of the stihl ones,
as said above, pretty fragile (new shaft £200 :blushing:)
but we were doing rail work and got an Echo one, it lasted for half a shift !!!!
got a four mix long reach as well as the pole pruner, they're brill, you can really feel the torque :lol:
i have the stihl, the 4 mix is a bit heavier than the original 2 stroke. it has more grunt and i have never had any problems with the bearings in the shaft. This was always the problem with the earlier models.
I use mine daily and with the hedge cutter head on, it handles it no bother, i have even had the strimmer on it for a laugh and it was fine.
I have had that 1 for about 3 years i think, usually i went through 2 a year.
Never tried the echo, i see no point!
