10hp diesel 2 wheeled tractor
evergreen
Hi Gollum
Thanks for the advice I will check the av mounts.
it looks similar to yours, has got a rear roller, I cant remember off hand whats on the makers plate, but it is Italian. I find it lifts up easily on the front when you run over obstacles, even apples! i didnt know whether to put some extra weight on the flail to keep it down. What do you think?
Hi Gollum
I have extra weight on the pull start end and wheel spacers to give a wider foot print. Makes it easier to turn on the brakes.
I get my boys to do ten minutes on it and then swap with the guy on the clearing saw for another ten. Worst thing is rutted ground- all you can do is lock the diff and hang on for grim death! Mine has no castor wheels at the front so has an annoying habit of stopping dead when the front bottoms out in a rut, leaving you to walk into the handlebars.
Oh, and if you're not in third gear you're a pansy :D
