I was tipping some chip off today when suddenly the pump packed up, luckily it was nearly all the way up.
Battery good
Solenoid working- can hear it clicking in and out
Insulator switch working
All connections are sound
Went to my local dealer they said I need a new pump
£££££££ 385 + VAT
Vat
Holy moly
Anyone know where I can get a better deal ??
Oh and on the new pumps they have a different plug to the older models so you have to buy that as well.....
I am gutted as I am not even vat registered and living on the bread line.
  • Replies 24
probly wont help, especially if uv aready checked, but ours stops working interminantly beacuse the cable gets pulled out of the plug / remote control, a simple push in gets it going again, just a simple idea to try before you part with your cash!
Yes. I checked that. Thanks anyway.
£££££££ 385 + VAT
Vat
Might be possible to source new motor and fit it to existing powerpack. Any info on the motor itself?
The motor is not much more than a starter motor, check all the contacts, if that fails take it to an auto electrician and get the motor checked out.
It’s unlikely to be the pump.
Solenoids on my winch packed in . when operated solenoids make a ticking noise . Maybe your hearing this noise and mistaking it for the solenoids working noise? Maybe your switch why not try to bypass it :001_smile:
