Reverse drive tractors
David Riding
valtra and fendt are the obvios because as far as i know they are the only flat cabed machines everything else i've seen the seat is built into a suround
some of the less well known makes might have flat cabs i've never worked with the likes of same and landbourgini
  • 2 months later...
how you getting on Dave, if its for mulching youd be best with a fendt by a mile, ive had valtras and valmets and they all top out at 200hp which isnt much to power an 8ft head by the time it powers everything else too, fast tracks are rubbish for reverse drive mulching as the lifting arms are so far away you cant see whats going on, a cheaper option to installing a reverse drive is to change the gear box on the mulcher so it can be inverted and fitted to the front linkage of the tractor. at the end of the day if the budget fits you want a reverse drive 936 or similar. or use the seppi on the excavator ;-) cheers. simon
Don’t forget that there were reverse drive MB-Trac and later MB-Trac based WF-Trac.
The trouble with front mounting mulches on conventional tractors is the risk ejected debris pose to the driver given the much-reduced angle between the hood openings and the seating position vs. rear mounting, you also have the problem you end up with a bulk of the weight on the smaller front wheels so they are more prone to sink.
