half hour cedar speeded up into 9 mins got bored and felt like makeing another video :blushing:
[ame=http://www.youtube.com/watch?v=yBWwUtCJmQU]‪half hour cedar speeded up‬‏ - YouTube[/ame]
Speeded up that makes me quite sick. Did you rig all the limbs off the back? Fantastic work as always.
yer i spiked down as far as i could cutting and chucking then about half way stuck a pulley up rigged a couple bigger ones and all done :001_smile:
  • 3 weeks later...
Cool, i threw on one of my dnb tracks for backround noise instead, worked out polyrhythmically better at 180bpm.
May i ask why climbers dismantling a tree use their hand saw at times, and not their chainsaw? Is it to break up the balance a bit, or is it a safety thing?
Nice smooth work btw, sped up or not.
Were you high enough to feel the trunk bending between your strop and spurs ?
ooo yes it was getting to the point where the tops bending over not with the rest of the stem :001_huh:
i just used my handsaw mostly because its easier/ safer to cut and hold with a hand saw rather than the chainsaw if i could have just dropped all the limbs i would have just spiked up with the saw running constantly taking everything off as i went, just some stuff needed lowering on the roadside.
