A little poem to help you,
Beech Wood fires burn bright and clear
if the logs are kept for a year
Store your logs for Christmastide
with new cut Holly laid beside
Chestnuts only good they say
if for years its stored away
Birch and Fir will burn too fast
blaze too bright and do not last
Flames from Larch will shoot up high
dangerously the sparks will fly
But Ash Wood green and Ash Wood brown
are fit for a queen with a golden crown
Oak Wood logs if dry and old
keep away the winters cold
Poplar gives a bitter smoke
fills your eyes and makes you choke
Elm Wood burns like churchyard mould
even the very flames are cold
Hawthorn bakes the sweetest bread
do it is in Ireland said
Apple Wood would sent the room
Pear Wood smells like flowers in bloom
But Ash Wood wet and Ashe Wood dry
a King may warm his slippers dry
Hope this helps :001_smile:
Oh no :001_rolleyes: Not this crap again!
No, no, no, no, no - This is what we have to contend with; I'm sure other's will agree :biggrin:
That poem makes nonsense of reality.
Ultimately, any wood if properly stored and seasoned will burn.
Phew.
By far my favourite wood to split is sycamore whether by axe or splitter.
:thumbup1:
I will split and sell any wood.
The only real tricky stuff I have found to split is big monterey pine. Very sappy, heavy, knotty and awkward... :sneaky2:
What firewood wouldn't you touch?
What is a bugger to split, a bugger to season and when burnt doesn't burn well or give off much heat?
As a consumer, what I'm asking is what are the woods to avoid?
Depends if you're paying for it. If it's free then you'll burn almost everything and anything. Better to have something on your fire for free than to have to pay or have nowt eh?
As for my faves? I like a mix. I like Cypress or Fir for kindling and to get a bit of go in the fire and then I throw the good stuff on. I have some old daddy Gum I cut down about a year ago and it's almost seasoned now. Burns hot and long. Some of the NZ natives are hot enough to melt fire grates. Willow I don't bother with and I never used to bother with Poplar either but a lot of people I talk to around here reckon they are happy to burn pop. It just doesn't last long.
What's a bugger to split? Seasoned old daddy Gum. Even a hydraulic splitter won't bust apart the the knotty bits and if you can bust em open they explode. Had a mate of mine took a swing at a hunk with an axe and thought he was going to lose his teeth with the vibration.
