i need a combi spanner, scrench, call it what you will..... for my husky 346xp
do i need the 13x19mm
just want to check before getting the wrong one
thanks
buy the normall stihl one,, one of the sides fits it.
Would you not then get a Star key thing on the top?
The bar nuts on a 346xp like all huskys 13mm,
no i meen the one with the flat srewdriver on the top
they generally have 2 sizes on each one for the side plate and 1 for the sparkplug
yes 13mm for side plate and just check it,s a flat screwdriver end
You need a 13mm / 19mm Scrench - the Stihl one will have a torx 27 end, the Husky etc ones have a screwdriver - I will let you work out why it is called a Scrench:thumbup:
This is assuming your 346 has its correct plug in place!
All the stihl chainsaw ones I have have screwdriver ends. The hedgetrimmer ones have a torx end. They are a couple of quid from a stihl dealer
