How many can you link up? as many radios and headpiecies as you want?
Do you have to keep hold of the button to talk, or can you press it once, talk hands free, then press it off?
can you have one radio without the ear piece and one with working together?
Thanks!
Josh, so long as all your radios are tuned into the same channel you can have as many as you like. To communicate yes you hold the button in and release after you have spoken, we opted against VOX control as this system makes you think about what you are doing. Also with VOX system you will end up listening to everyones conversations which could distract you. The Midland Radios have a facility to beep before and after your communication, called ROGER BEEP.
If you just wanted one Communication Device you can and the other person can just be holding the other radio - simple
  • Replies 72
The fitting on the headset is listed as Standard, this will work on a range of 2-ways, such as Alan, Alinco, Icom Cobra Intek and several other makes of the commonly used PMR446 range. It is possible to buy adapters to convert to other models of radio, though probably easier to ask at a radio suppliers such as Maplins whether your radios are "Standard" fitting.
And will they be available for purchase at TCI in Hartford?
Hi Brendon, I will have a demo set at TCI next-week, come along and have a go.
Is there a ring or loop on the radios so if it comes unclipped from where ever it is clipped you can hang into it via a small karabiner ?
When we used them they fit perfect into the chest pocket on the STEIN Evolution Jackets. We also put the in empty First-Aid pouches on the harness, some actually put the radio into the large leg Trouser Pocket. There are also simple radio harness available. search google for Radio Holster
Daft question, is it only the left ear muff that they're fitted to?
As a special order you can have one made in the right muff if you wish. 2-3 week delivery
Hi Andy, this is correct the fitting will fit many other radios. We recommend the Mindland G7E XT as we have tested these over a period of time and this radio has proved to be excellent when operated near small powered equipment. Some cheap radios can be affected by this causing crackling and white noise.
