This is the rope guide that I made its pretty much finished other than I need one of those cambium saver retriever but not if it it will fit through the standard size pinto:confused1:
Do any of you know if it will or not??
Have you tried it out yet?
I'm curious to know if your line will rub on the rope at the wee red krab and pull this krab up into your Pinto.
It looks like it might be tight enough to do so when that part of your RG is hanging at an angle.
I havent tried it with the little red krab yet at first I jus had a loop of the rope with some shrinktubing on it but change it because couldnt get the loop small enough to stop the eye passing through it so Im thinking either a small cambium saver ring or maillion
Looks good....and home made.As long as its retrieves sweet,Just watch the wee tool clip going into the pulley when climbing(decending)
  • 1 month later...
what knot is that, that you've used on the large eye?:confused1:
half fishermans with an extra wrap???? its same as the small krab knot
