Husqvarna 346xp
FIFTYFEETUP
Hi, just recently bought a brand new 346xp. When i adjust chain correctly, and turn it slowly on bar, it stays at the correct tension apart from one place during the full rotation, where chain drops and goes slack only by 2-3mm, but it is noticeable, then if i continue to rotate chain, it returns to correct tension again, i have checked chain for any tight rivets, has any one else had any similar problems with the 346xp. Wondering if its something bent or off centre somewhere. Anyone know of anything similar? Regards andy
maybe put a mark on the chain where it goes slack and see if it's the same place each time. If it is a different place each time, I'd say sprocket/crank related, if the same each time then most likely chain related.
Good advice - it is going to tell you if it is chain related or clutch or bar sprocket or bent crank shaft - good logical fault finding:thumbup:
  • 3 weeks later...
Hi bob, sorry for slow reply, been busy, using the good weather, took it back to supplier, they fitted a new rim sprocket, and it seems to have cured the problem, maybe it was a slightly off centre casting. If left could have caused vibration damage to crank maybe??
