  • Replies 498
don't think its the dryinus?
I agree, much too reddish brown for a dried out Pleurotus dryinus, which mostly also has an excentrical stem, so based on the colour and the absence of a stem, P. ostreatus would be right.
for some reason i just don't think it is P. ostreatus, i know your the expert and i'm probably wrong:lol: but it just doesn't "feel" (gut) like it??
i have also looked on the fugin directory too david but alas to know avail i keep finding it difficult to identify things unless i trawl through each one singularly:001_huh:
Hi Rob,
Do you use the Search Key Word function?
For instance, if you type in 'mushroom' to the box, the directory searches the gallery list for 'mushrooms'
I ran that & it came back with a list of 12
Included was Pleurotus ostreatus, as an example.
If you searched for 'bracket' it comes back with a list of 25.
Also you could try searching, colour, pores, gills etc........
So you can narrow it down quite a lot, without having to trawl through all the 70 + galleries.
Hope this helps :thumbup1:
Rob,
After developing reddish spots on top, P. ostreatus entirely turns pale to reddish brown.
whats going on here (we took this padus down as a result)
Rob,
Did you also consider you could be dealing with Tripe fungus (Auricularia mesenterica), provided the brackets have a gelatinous or rubbery structure ? Maybe Tony can have another look at it ?
Found this Polyporus squamosus on a Tilia sp yesterday on an old storm tear. Target unfortunately is a kiddies playpark. The significant size of the fruiting body suggests it is flourishing well and has plenty to consume? I am considering making a recommendation that it be removed on the grounds of safety as it is a white rotter and therefore tensile and compressive strength is diminished. This tree will be subject to windsnap I suspect? Your verdict would be welcome :001_smile:
There is also another smaller bracket of the same species in the picture further up the stem on an old pruning wound :thumbup1:
Edited by armybloke
