you need the figure of 8 or similar above ur hitch bro, as that takes out the friction that would of gone onto your hitch.
Figure of 8 goes below your hitch and the hitch is just there as back up
  • Replies 28
The problem with a single line and extra wraps on the friction hitch is although it will catch you you will be unable to descend without a figure of a 8 or similar descender below your hitch.
Unicender solves this problem! It's designed for SRT.
Has anyone on here gone through a steel flip line accidently or on purpose?
Cut mine up pretty bad, didn't even know i'd done it. Don't use them anymore.
[ame=http://www.youtube.com/watch?v=Siw0nXZVi9E&feature=related]YouTube - chainsaw test on wirecore flipline[/ame]
[ame=http://www.youtube.com/watch?v=0h0x08KDSMQ]YouTube - chainsaw test on wirecore flipline[/ame]
if anyone local wanted an old metal strop to try i have more than i need:blushing:
bob, have you tryed it using a 66,:biggrin:
Husqvarna dont do a 66 anymore:confused1:
used a 395 and pretty quick across but in general the cut should be more down the length which will add a bit and the sparks certainly are an indicator:thumbup:
How about using the figure 8 with revolver on the running bowline? It even allows you to ascend if your desperate!
[ame=http://www.youtube.com/watch?v=XyXwrXgN0qw]YouTube - the F8 revolver[/ame]
Cheers
