  • Replies 49
  Mr Ed said:
the Farm 2000 boiler is about £7k. Very expensive IMO.
That would probably be about the same cost as two years oil to heat my place:scared1:
Big boilers do come up S/H from time to time.
i have a log burner and have you really thought about cost
if i did not burn it i could sell it
i use tons of the stuff as its free
if i had sold what i used last year approx 7-9 ton that would have been a lot of oil or gas
and as fuel prices go up so will logs £££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££££
  Mr Ed said:
As an arborist, I'm always running out of firewood because I have NO TIME....
Pellets may cost, but they are sustainable, carbon nuetral, convenient and clean....
so what happens to all that wood you cut down??:confused1:
The only reason logs are cheap is because we have them, but with cut and split logs making £60 a cube, how do pellets compare price wise? I see that some of those new-fangled eco-type houses have had the pellet-fuelled systems installed.
You only need a heat tank if you are burning firewood, the pelet master will run a 4 bed house with 2 bathrooms on aound 3 tone of pellets a year, think of the savings over oil, I know you still need to buy the boiler but the return is quick. It also fits right into you original heating system with little plumbing
Read more
