My general rule of thumb is that the bar should be 1/3 of the cc of the saw - more applicable to groundsaws though - 60cc = 20" etc.
12" & 14" is normal on a MS200T, it will cut well with both - save the 16" for the rear handle model
exuse my ignorance but whats a ported???
:dito:
Exhaust Port on Muffler/Engine has been enlarged.This allows more rapid escape of Exhaust Gasses allowing more Fuel/Air to be Aspirated and combusted thus resulting in Higher RPM and Tourqe.
Why on earth would you want to?
Unsafe and underpowered - bad combo!
Why do you say it's unsafe? I've run one of my 020's with a 16" bar when doing a lot of big spruce takedowns. I wouldn't want to disc down an oak with it but if you are sectioning big bits on the way down it's fine.
I guess I should have written "less safe" rather than "unsafe".
Longer bar => less safe when using in tight spaces (conifers), and much greater risk due to kickback, which is difficult to control with a top-handle in the first place.
I have seen a couple in the repair shop....or maybe the same one twice. TBH i can see a point in it, although it makes the nose so heavy that the saw HAS to be held two handed (lets not get onto any 'well it should be held 2 handed anyway' stuff BTW) so you may as well get a rear hander up in the tree anyway.
