200t wont stop
Ollie Wall
Black wire under the front of the top handle.
Also check your rubber av mounts, as if they are starting to wear there will be increased play in the handle, which can cause the wire to pull off at the spade terminal under the handle.
Lucky you didn't get a big belt off the cap:001_huh:
Probably the black wire has come off the spade connector behind the front AV mount or the earth wire has fractured or come loose - fairly easy fix - you can meter them to find out if the wire is broken.
Most people pull the choke on to kill the engine if the stop switch fails:thumbup1:
