Take an oak tree, freshly felled. It's 20" in diameter at the base and about 35 feet tall. The branches have been removed.
What would be a good estimate of the weight of the main stem?
  • Replies 26
Look in your forest mensuration book, blue book
if your desperate to know and don't have one I'll look in mine but that will require me getting of my bum
I don't have any mensuration tables, so a quick calculation:
Assume it's a cylinder, average diameter of about 12in
Assume, being wet, that it has a density of about 1kg/dm3 (same as water)
Convert to metric - 0.3m average diameter, 11m long
pi x radius squared is 0.0675m2 end area
end area x length is approx 0.75m3 so approx three quarters of a ton.
I'll be interested to see how wrong this is!
Alec
Alec
just checked my tables.. i had 0.79 but ur close enough :lol:
One of my charts says oak at 50cm diam weighs 165kg per mtr.
Oak at 30cm diam is about 59kg.
If its 20 inch at the base and tapers 'typically' the average diameter would be say 12''
Approx. 10 mtrs at an AVERAGE of 12 inch (30 cms) would therefore be 590 kgs
But the extra weight at the bottom would be more than the reduced weight at the top
so it would probably be a bit more - best part of a ton. But thats my chart.
Variations in season with moisture content, rate of taper etc.
