had a frustrating day trying to fell a large pine tree. the result is one hung up tree and a bent bar. should i try to straighten it or should i get it done by someone who has the right tool. i need it perfectly straight for milling. and the last time i tried on a smaller bar i ended up with an S bend.
Thats a big bar to bend. You'll more than likely need to get a new one as they just never bend back totally streight. Even if you do get it right they'll always be a kink in the rails which will knacker the drive links of the chain.
I've never tried straightening one but it may be possible.
A bar this length will be solid and not laminated.
What make was it by the way?
i looked at those on your old site ages ago, they look brillant! if funds allowed i would probably get one, i can see it being handy
why? Do you intend to bend many bars?
